700r4 B and M shifter work on a th350?
I have a 700r4 with a B and M ratchet shifter in it. Im going to change my trans to a th350. Will the B and M shifter work on my th350 also or is that shifter just for a 700r4?
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 700r4 B and M shifter work on a th350?
I've run this setup before without issue. the B&M kit should include the correct cover and instructions for swapping over to the 350 setup. Here's a link to their instruction guide:
http://www.bmracing.com/bmracing/ins...truction/8.pdf
you will have to make some adjustments, but everything should be in their instructions.
NBrehm
08-25-2015 11:49 PM
