very concerned about this vibration!
Car: 85 camaro z28
Transmission: auto to manaul
i bought a 85 camaro from my buddy with a automatic. i put in the t56 trans because the automatic was bad. So i never got to drive it with the auto, now i have a very bad vibration at high rpm and high speeds. The engine is a 305 gm good wrench, not sure if this is a internal or external balance engine. im hoping this is just a bad drive shaft, but it looks fine. my tires are bad, but i dont think it could cause vibration like this. any help or ideas would be great
Car: 85 camaro z28
Re: very concerned about this vibration!
ok i found the sales receipts for the engine, it looks like its internal balance. gm part number 12531687.
http://www.sdparts.com/product/12531...ateEngine.aspx
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i have had some crapo tires shake like crazy, also the steel driveshafts commonly have troubles in our cars, getting it rebalanced wouldnt hurt
Car: 85 camaro z28
my tire are very bad, but ive never seen tires cause vibration like this. i can feel alot of vibration from the shifter. im goin to look into getting new tires anyways. i will try to get it balanced or another used one in a week or so.
1 Post
here is the thing on the used one, so many steels had trouble you may just get another junker, if you got a drivetrain shop local its prob worth it to have them balance it, if you aint got one local try replaceing the u joints that may help some
but i have rode it a fully restored 3rd with an alum drive shaft and it hade some vibration in it, i dont think out cars will ever be smooth as a new one at 75+ but i may be wrong, i know they sure aint as smooth as the honda
1 Post
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
What are u running for a cross member , also look behind your harmonic balancer see if there is a weight in it . With that motor you would need a special 2-piece flywheel .Witch flywheel do you have . Don't spend your money on tiers yet .
roysatikas
09-22-2015 08:15 PM
