LT-1 T56 converted to LS-1
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Hi guys, I'm thinking of going LS-1. I now have a vortec 350 with a t56. Have any of you put a LT1 trans behind a LS1? I know the bellhousing and input is different. Any other differences? I already have the t56 mounted and driving and I love it. Will the crossmember need to be moved or are the lengths the same? I can get the engine only for about half the price of engine/trans combo! Will the conversion be cost effective. Thanks in advance, Dean.
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: LT-1 T56 converted to LS-1
The midplate of the trans needs to be changed (for the LS1 hyd TOB slave). Other than that, you should be ok with lengths. If you have to buy a new LS1 Bell/input/mid-plate, it will run you about $500. Finding them used will help the costs of course, if you can. The mainshaft and countershafts should be reshimmed when doing the conversion, since the dimensions will change.
Engine: LS6
Thanks Mike, thats just what I needed to know. Dean.
Engine: LS6
Hi, I found a good deal on a GTO LS1 bellhousing. Would it work with the LT1 trans & camaro engine? Thanks, Dean.
(I assume you mentioned the LT1 trans and camaro engine still as part of your plan to drop in an LS1 motor and convert your LT1-T56 to the LS1 style...)
Engine: LS6
The GTO bellhousing is different in the starter area. If you use it, you must use the smaller/expensive starter from a GTO. Unless you have the GTO starter, it's usually cheaper to get a (sometimes more expensive) LS1 bellhousing.. Otherwise, the dimensions, engine mounting and transmounting of the GTO bellhousing is the same as the LS1 bell.
Yes you can.. It's some trial&error grinding , but it sounds like you can handle it..
camaro1185
10-26-2015 06:51 AM
