T56 Swap/Dakota Digital SGI-5 Speedo Calbriation Box.. How does this box hook up?
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
The mechanic that is doing the swap for me called me and said he can't get the speedo working correctly.. If anyone has used the dakota digital box please let me know how you hooked it up, and exactly how I should expect the speedo to act.. I know theres supposed to be some sort of delay, is that long or short? Is there anything else?
Need an answer ASAP so I can call him tomorrow from work and tell him how its supposed to be hooked up so he can have the car ready for me for after work! thanks!
1991 Camaro Z28
CURRENT MODS:
350 TPI, Automatic, Edelbrock Headers, Edelbrock Runners, Edelbrock Intake, Flowmaster Exhaust, MSD 8.5mm wires, Autolite Double Platinum Plugs, MSD Cap/Rotar, Random Technology high flow cat, Hypertech Power Chip (160 Deg Thermo), K&N Filterchargers
STEREO MODS:
Pioneer DEH-P6000, 2 JL Audio 12W3 subwoofers in custom hatch enclosure,
Rockford BD1000.1 Amp, Infinity Kappa 4x6" plates & 6x9's
WEBMASTER: www.thirdgenfbodies.com
1991 Camaro Z28
CURRENT MODS:
STEREO MODS:
I don't have it in front of me , but I'll try and remember.
Of teh two speedo wires going to the trans one stays connected to the trans. It doesn't matter which one. The other one needs to be cut and run to the box from the trans into the "input". A switched 12 volt source must be connected to "power"(from the fuse box) and any suitable ground may be used and connected to the "ground". That's the easy part. I had trouble at first finding which of the outputs I needed to use. I think I used "output 3" As long as you have the power, ground, and input hoked up correctly you just have to play with each output to get the correct range you need. The first two switches also have to be set correctly so the box knows what mode it needs to be in. One should definitely be off and two should also be off because you are converting a high speed signal to a much lower speed. Good luck!
88 firebird formula - 13.9 @103mph, 2.6 60ft
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
T56 - SIX-speed
open 3.73's
3 inch Flowmaster catback
I love pissing those LS1's off
My Formula
350 Vortec TBI
Edelbrock headers
T56 - SIX-speed
open 3.73's
My Formula
ambainb
04-25-2016 09:21 PM
beachrodder
08-07-2015 04:27 PM
