Rough shifting in the T5 NWC
Old 06-10-2009 | 03:15 PM
Markemery's Avatar
Car: 96 z28, 94 concorde,
Engine: LT1 and a 400SB in thoe works.
OKay so i recently rebuild my T5 NWC new counter shaft input shaft and master rebuild kit bearing and brass syncros.. i also installed a new clutch and pressure plate(its mechanical clutch) the issure im having now is that the tranny really seems to have some issue changing gears going into first can be tough as well as reverse last night i tried to go into reverse and it seemed like i was useing no clutch at all i had to shut the car off then put it into reverse and start it back up.
The adjustment is almost at the end of the rod i have aout half an inch left on it ...anyway thakn
Old 06-10-2009 | 05:27 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Rough shifting in the T5 NWC
Adjust it out further to see if it helps.
Old 06-11-2009 | 01:29 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
This is a clutch problem, not a trans problem. What clutch did you use?
novaderrik
11-22-2017 12:40 AM
doop327
02-29-2012 04:51 PM
89Firebin
02-06-2012 07:06 PM
Darkshot
09-13-2010 08:02 PM
