What are your opinions on 3.73's for a 350 TPI?
THe title says it all. Looking for more power, or just want to make it quicker, it has 3.27's in both now. Should I change to 3.73's in both of my cars? They both have the borg warner rear end.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
had engine fire
Flowmaster exhaust
LT1 Injectors
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">Borg warner doesn't make 3.73's. You can get 3.70's for them, but they are expensive and hard to find from what I understand.</font>
I have available (ie for sale) new gear sets and new series 3 posi carriers for the 9 bolt. I currently have 4.10 gear ratios and series 3 posi carriers in stock! Yes, for the 9 bolt! I will be getting some 3.4x and some additional 3.73 ratios soon.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">3.73s are avaliable from TPIS for $500 with all the berrings and instal kit. </font>
I have available 4.10 ratios with install kit for much less. I will also soon have available, 3.4x and the stronger 11 tooth pinion 3.73 ratio.
Miles
88 427 Camaro
www.koolmeister.com
How about precision gear. I have a old catalog of theres at work and they advertise 3.73's. Dated early 90's. 88 427 Camaro do you have any info on your gear sets?
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
had engine fire
Flowmaster exhaust
LT1 Injectors
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
had engine fire
Flowmaster exhaust
LT1 Injectors
I've heard a lot of people say that they have had better experience using 3.45s in thier TPI cars as opposed to 3.70s.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by AaronIROCZ:
</font>
</font>
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">How about precision gear. I have a old catalog of theres at work and they advertise 3.73's. Dated early 90's. 88 427 Camaro do you have any info on your gear sets?</font>
There is so much bad information floating around about the 9 bolt. It is much better than people think. And parts ARE available. They are more expensive than a 10 bolt, but much cheaper (and lighter) than a 9 inch or 12 bolt. The 9 bolt fills a void between the 10 bolt and the 9 inch in terms of cost, strength and weight.
Miles
88 427 Camaro
www.koolmeister.com
