dayco converters any good
I have a guy that is going to give me a 2800 stall dayco stall converter for some money he owes me. I plan on having 450fpt off the bottle. how long do you think it will last?
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit,2800 converter, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,holly afpr,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil,150 shot NO2. This car is currently under rebuild and restoration.
I've got a 2500 Dayco in my Z28 and it's done just fine since I put it in 2 years ago. But the Z runs mid-14s with a major traction problem, so I really couldn't say what it would do under 450 fp of torque.
Michelle
92 Formula 350
91 Z28
Michelle
92 Formula 350
91 Z28
Most Dacco converters are fine for normal duty. I have my doubts about HD use though. If you can drive the car now it would help so you could evaluate it. The oil must be cherry red also.
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Honestly, i don't like my dacco converter.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
My Dacco is working pretty good but I only bought it because I was on a seriously small budget at the time - not because I thought it was the best thing since rear view mirrors. I wouldn't mind swapping it out for a Vigilante..........
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1987 GTA L98 MD8
My GTA
i had a 2500 dayco put in with my bullet proof tranny and it whined like a biyatch and reverse was wierd so i had them put a vette verter in and its been cool, you think i need that plastic converter cover?, they left it off
89 iroc 5.7 can't go fast enough. 14.1
http://www.picturetrail.com/irocsean
1992 Trans Am
05-10-2023 07:19 PM
3000, 3500, converter, converters, dacco, daco, dayco, forum, manufacture, manufacturer, nc, phoenix, stall, torque, transmission
