Can 3.08 gears work in a 3-series?
Is there ANY way to get 3.08 gears to work in a 3-series carrier? Is there a special ring and pinion I can get from somewhere?
Or is this just physically impossible?
I'd like to get the cheaper $99 3-series Torsen LSD carrier from SLP and install 3.08 gears on it. I do a LOT of highway driving (80+ mph), and 3.23 just seems like too much for my needs.
What do you think, is my quest for 3.08 stupid?
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You might want to check with Richmond Gears. For a 10 bolt rear end, I think that they have gears for the opposite situation that you have (3 series gear ratios on a 2 series carrier). Maybe they can help you.
Under normal conditions, you can not put 3.08 gears on a 3 series carrier.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 3000 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, 24#/hr SVO injectors, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(50psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.27sec @ 103mph on MT ET Streets
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Car: 4
Engine: 6
Transmission: 5
No they cannot be made to work. The ring gear would have to have a negative thickness.
The difference between 3.08 and 3.23 is negligible in terms of engine RPMs, gas mileage, etc.; I think they would serve your purpose as well as 3.08s would.
ICON Motorsports
ICON Motorsports
Car: 82 camaro SC
I agree, the difference in 3.23 would see no difference in mileage. Gear ratio doesn't hurt mileage that much.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
knight72
08-10-2015 09:32 PM
