T56 Slave / master cylinder leak?
I believe my slave cylinder is leaking on my T56 but I am not positive. I have a little transmission fluid seepage around the transmission which I think is normal, it's very little. By the slave cylinder where it goes into the trans and connects to the fork seems to have a drop or two hanging on it everytime I check under the car... Well, my question is this. Where can I get the slave / master assembly and how much? I would prefer not to go to the dealer for this but if I must, I will. Also, when I did the conversion, I had the motor and trans out of the car making it a lot easier. Do I have to pull the brake booster out or anything to do this? Any help is appreciated.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T56 Slave / master cylinder leak?
The clutch Hyd. will use a Brake Fluid, not Transmission fluid. Have you notices the fluid level of the Clutch Resivior getting lower?
http://www.rockauto.com has the complete assembly, and Autozone has either master or slave as separate pieces.
Taking the brake booster out makes the master alot easier to get to.
Street Lethal
09-07-2015 01:09 PM
