THM 700 R4 shifting gears manually
Car: 91 Trans AM,Bright Red, T-Top, WS6
Engine: 305 TBI
I have a stock 305 TBI TA with a Transmission cooler.
-i drive long distance 60 mph without using overdrive, just in "drive", because the exhaust noise is a lot louder a lot louder then in "drive" at this speeds..
-i also drive 30/40mph in the "2" second gear. faster then 40 mph i shift up in "drive", also because the exhaust noise is a lot louder then in "drive".
all speeds arround 2000-2200rpms.
sometimes i acclerate in first gear from zero, so i shift the gears manually.
i think this is bad for the tranismission?
is this safe with a stock THM700R4?
thanks
thanks
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: THM 700 R4 shifting gears manually
It's not bad for the trans. You are wasting fuel driving like that, and I'd like fuel to stay cheap, so we all have to do our part to try and get the best milage in whatever we are driving. On a stock trans there is little if any advantage to shifting manually. With a shift kit you will get a faster shift, even without converting to full manual control.
84 TA NV
09-06-2015 08:02 PM
1992 Trans Am
08-08-2015 08:16 PM
