Thinking about a t56 swap.
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
I'm seriously thinking about doing T56 swap to replace my 4l60E. As of right now I'm trying to compile a list of all the parts I will need to in order make this swap as least painful as possible. I have been reading all the T56 swap threads and I have an idea of whats needed. I just wanted to have you guys take a look to make sure I'm on the right track.
T56 Transmission
Bellhousing
Clutch
Flywheel
Pressure Plate
Master and Slave Cylinder
4th or 3rd gen pedals
Throwout bearing
Bellhousing Bolts
Bellhousing to block bolts
Flywheel Bolts
Shifter
Shifter boot
If you guys have any part numbers or recommendation on parts feel free. I would upgrade from stock parts to higher performance parts because I plan to get on it from time to time.
Thanks in Advance,
Jay
T56 Transmission
Bellhousing
Clutch
Flywheel
Pressure Plate
Throwout bearing
Bellhousing Bolts
Flywheel Bolts
Shifter
Shifter boot
Thanks in Advance,
Jay
ambainb
04-25-2016 09:21 PM
