Attn: Pro Built Automatics / GMTech dudes
Hey since you guys seem to be the most knowledgeable about transmissions, I've got a question. My 700r4 has been slipping for some time now, and its got to the point where ive been manually shifting for about a month. For about a week now a clanking sound was coming from what seemed to be the trans/flywheel. Last night i was gaining speed on a highway, and i shifted into third and i heard "CLUNK CLUNK BANG" and when i hit the gas it felt like i was in neutral. I rolled into a gas station, and my car stalled. Now when I try to start it, it sounds like the starter spins and just doesn't catch anything. Im just wondering if my trans is totally destroyed, if the flywheel exploded, or whatever... just drop some ideas at me so i can take a proper course of action with my IROC. Anyone is welcome to respond... thanks in advance...
Jack
1987 Midnight Blue Camaro IROC-Z, 350 TPI out of an '88, Accel 8.8 wires, hypertech air foil, flowmaster american thunder 3" dual outlet cat-back... slipping tranny!! (T5 swap next spring!!)
http://banners.wunderground.com/bann...hackensack.gif
Jack
Read the last sentence!! It says "anyone is welcome to respond" heh ... thanks again
Jack
Jack
Car: Take
Engine: Your
Transmission: Pick
I guess I'm obligated to answer this since the others are going to cry over the title.
Sounds to me like the flexplate has broken. You should be able to remove the Torque Converter sheild and take a look at it. You will probably see that the ring gear is no longer attached to the crank. That would be my guess.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
Buggy Disaster
09-22-2015 01:15 PM
84 TA NV
09-06-2015 08:02 PM
