Balancing a driveshaft in central FL
1 Post
Car: 91 Camaro Z28
Engine: L98 5.7L
Axle/Gears: Ford 9" with 4.30s
Does anyone know where I can get a driveshaft balanced in central FL? I am in Melbourne and none of the locals know about anything nearby. There *has* to be a shop around here somewhere, at least over by Orlando. Any suggestions?
1 Post
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Balancing a driveshaft in central FL
don't know about locations out there, but if it's a steel driveline, don't bother.....it won't fix the vibration.....
if it's aluminum....then I can't help either....across country from you....
just in case you have a steel factory driveline...here is a link showing some good info.
https://www.thirdgen.org/forums/tran...iveshafts.html
The steel line 'worrbles' or 'bends' at speed, usually 65-70 or higher mph. Found this info in car craft showing how 3rd gens have a bad designed line.....
Hope that helps something......LOL
1 Post
Car: 91 Camaro Z28
Engine: L98 5.7L
Nah it's an aluminum one. Otherwise a quick junkyard trip would solve this
1 Post
Engine: L98 494hp
LOL....good deal....have just seen so many post about vibration, and driveline is last thing people think to change out.......sorry can't help ya any....in idaho here....good luck though.
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
monte87cortez
09-26-2015 08:10 PM
Hill1513
09-19-2015 04:15 PM
