Best way to mount B&M trans cooler?
Car: 2004 GTO
I just ordered the 16,000GVW cooler and wondered how I can mount it. It looks like a tight fit in front of the radiator. I am wondering how the fluid lines run around the radiator?
Any advice will help! Thanks!!
You have to put it in front of the radiator in the air ducting. There is some gaps that you can route the hoses through. I like to take the extra hose, cut it into a spiral and put it wherever the hose might chafe. Bypass the radiator too.
I put mine in front of the condensor. I ran the lines up to the top corner of the radiator and put them through a piece of old radiator hose so they will not get cut. I have a TPI so I just ran them around the air box and charcoal canister then down to the trans lines.
ambainb
04-25-2016 09:21 PM
