Need: Drive shaft for TH400 swap
1 Post
Car: 1988 camaro
Engine: 355 SBC
Transmission: TH400 w/ 3800 stall conv.
My son and I are working on a 88' camaro project! It now has a built 355 and TH400 trans! Any one have a drive shaft setting around for this application? Stock rear end!
Any information on where to get one,,, would be appreciated!
Kevin Baden
kbaden@yahoo.com
Kevin Baden
kbaden@yahoo.com
Engine: IVTEC 2.4L aka SBC
Transmission: auto
Re: Need: Drive shaft for TH400 swap
i have the same set up in my car.. (basically) measure how long of a drive shaft you need, and head to a you pick it junk yard. find a drive shaft that is the correct length and swap the yokes from the old drive shaft to the new one. the drive shaft i found (i think) came off of a ford truck or van so i had to get new u joints to make the chevy stuff work with the ford stuff. all in all i think i spent 40 for the drive shaft and anther 100 for the new u joints and yoke, and to have it balanced...
1 Post
Car: 1988 camaro
Engine: 355 SBC
I contacted the following company and they were awsome! Told him what I wanted to do and he looked it up in about 30 seconds! This yoke is a little long so you can cut it to the length you need! It is made that way just for that reason!
Here is the link! http://www.drivetrainspecialists.com/index.html
The part number for the TH400 swap is 40032054. The price is $68.00 plus shipping!
This is made for the stock replacement u-joints!
I hope this thread helps more of you gear heads!!!
Thank you for the replys to my post!!
Kevin Baden
Kevin Baden
BOSSENABLE (03-20-2023)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You're going to need a slip yoke for a TH400. It's a larger diameter output shaft for the transmission. Finding that slip yoke will be hard enough. You can't use a bolt on yoke commonly found on pickup trucks with a TH400 and a 2 piece driveshaft.
Factory driveshafts are not very strong. It's better to buy an aftermarket driveshaft or have one custom made. I had mine custom made and it uses 1350 u-joints.
GM u-joints are called 3R. Ford uses 1310 or 1330.
Car: 88 iroc z
Engine: 427 small block stroker
Transmission: th400 built
im gonna be doing this swap cant i just use a yoke off a car that had a th400 in it i got a extra th400 that came out of a older corvette
1 Post
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
i have a spohn driveshaft for sale.
its the Top Gun short tail TH 400 driveshaft.
http://www.spohn.net/shop/1982-1992-...hort-Tail.html
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
