torque bar bushing
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
torque bar bushing
I've found out that it's the torque bar bushing or lack thereof that is causing the bangs when I am slowing down, but autozone doesn't have one for me to purchase and the dealer keeps hanging up on me.
Does anyone know where I can get one? Thanks
1 Post
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: torque bar bushing
Autozone should be able to get one for ya....but a schucks/checker/o'rielly auto parts, NAPA....anyone should be able to get one....but there are two different ones for torque arm....it's in the shape of a W....one with the W facing left and one with W facing right....make sure you look and order right one....I ordered mine online through I believe Energy suspension....or at least you can get a part number through them...I bought a poly urethane...better than rubber. hope that helped.....oh don't buy from dealer..they way way way overcharge..
![your welcome](https://www.thirdgen.org/forums/images/smilies/welcome.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
a parts store can get you a stock rubber one, or you can get the aftermarket urethane one for about $20.
1984 and before was facing one way, 1985 and after was the other model. So just tell them you want the one to fit a 1990 Camaro.
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yea go and get the poly one and get a poly trans mount to while your at it, jeg and summit have both
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Alright, i see one on jegs for 11 bucks.
how do i install it? does it just slip on? it goes in this little square housing right? i'm pretty sure mine is missing alltogether
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
I got the Jegs one it works great, goes in the little squarebox, make sure you use alot of the polygrease, keeps the noise down...
1 Post
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
but yea that box will "come apart" but the bushing in it use a bunch of greese and be ready to cuss some
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Be careful not to push arm in too hard while mount is loose! I did and broke my speedo housing! Stupid Me....
JamesC
Just put the car on jackstands and support the rear end w/ a jack, when you install the arm make sure that the rear end is near level w the tranny, it's not that hard...
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
I'm gonna order it off of jegs, but can anyone tell me if my year has the bushing with the lips facing toward the driveshaft or away from the drive shaft?
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
It'll only go in one way match the W to the torque arm... Just looked on mine, the lip faces the rear of the car...
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
I checked under the car today, but i don't understand which one to order because it says "with the lips facing the drive shaft or away from the drive shaft" i looked and the torque arm is on the driver's side of the differential and the torque arm bushing is near the middle of the car, near the tranny mount, so it goes from the rear diff to the middle of the car where it connects to the torque arm bushing, but how can it be facing the drive shaft if it runs parallel to it?
1 Post
this should help ya
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
ah, hell yeah, thanks alot guys, sorry for all the confusion and frustration i've set upon you
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
I got the part, unfortunately it was the wrong one, they sent me the wrong part. anyway, the instructions said i had to either drill out or cut off the rivets on the bracket, is this necessary?
1 Post
im not sure, i had no rivits on mine when i reinstalled my trans, but i also paid someone to put the bushing on back 2 years ago on my first rebuild (that craped out in 8k miles).....when i put my new trans on all i did was unbolt the piece put it together and bolt it back together
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Bump
Anyone know? The correct part will come tuesday, should I just try to shove it in there anyway? I mean c'mon, the rivet sticks out like a millimeter or two, a little squeezing can't solve that?
BTW it was hell removing the old rubber bushing, I had to burn it to soften it up and scrape it off with a variety of exacto knives
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Omg, it was horrible i tell you.
It's the hottest freaking day of the year here and california, and it also happens to be the day the CORRECT part comes.
That torque arm has so much tension, i had to pull and hold it as hard as i could down to fit that little bushing over it, only to find out that it's just too freaking fat. I had to take it off, do some "fabricating" to the bushing (cutting about a centimeter off the top and half a centimeter off the side with a steak knife) to fit it in.
On the upside it doesn't clunk when i downshift anymore!
and it feels like the car jumps forward when i step on it, and the tires keep chirping when i pull out.
1 Post
its not a fun job but its will worth it, i also welded my tq arm up solid to, it really hooks up good now
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
1 Post
no, i took flat plate steel and welded it over the tq arm, on the side facing the left, making it to where in dont flex anymore.....should of taken pics before i installed it, may crawl under and take a pic one day
camaro1185
10-26-2015 06:51 AM
