weird vibration
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
weird vibration
first of all sorry for all the spelling errors. now moving on i swapped from automatic to standard and i get this weird vibration whenever i shift to 5th. 1st through 4th i dont get vibration but as soon as i shift to 5th the whole car begins to shake it is more pornounced at the shifter i swapped the driveshaft thinking it was the problem and although it helped didnt fixed it. when i had it on the stands i decided to start the car and shift trought the gears and i noticed that it will make a weird noice from the driver side wheel (by the way i have 3.08 STD with 275/60/15 wheels) also i dont know if its normal but also that wheel will spin while in gear (on the stands) but not as fast as the one on the passanger side and there is a lot of noise coming from the differential from the driver side but not like grinding more like if there was something broken inside any help ideas or appreciated sorry its this long and confusing
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: weird vibration
Check your driveline & pinion angles.
roysatikas
09-22-2015 08:15 PM
