How do gears affect the dyno
Car: ws6
Engine: ls1
Transmission: m6
Would a car with 2.77's dyno the same as a car with 3.45's or would the lower gear affect the dyno? If so by how much.
thx
thx
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: How do gears affect the dyno
they don't. try it yourself. dyno the car with 2.77s, then re-dyno with 3.45s. Your results printouts will show within about 2%.
Car: ws6
Engine: ls1
Transmission: m6
On Probation
Engine: several
Transmission: none
Axle/Gears: none
So long as you tell the dyno guy what gears you have, and if you corrected the speedometer, and if not what gear it was correct with, you will get an accurate power number.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't even have to tell the guy what gears you have. It'll infer the total drive ratio itself.
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
The affect is basically the same % as the ratio difference, but slightly less because of the increased losses as gear ratios increase.
So your 2.77 car will see about a (20 - ~5) 15% increase with the 3.45 gears.
Engine: 383 Carb
Transmission: 4L60
No it won't, because the dyno knows both the engine speed and the speed of the drum and it calculates and corrects for gearing.
Engine: 383 Carb
Transmission: 4L60
Yes, it is simple physics.
Put an engine with 300 ft-lbs of torque at the flywheel into a car with on a rear-wheel dyno with 3.73 gears. Assume 15% drivetrain loss. Notice that the dyno doesn't read 950 ft-lbs at the rear wheels.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
My local dyno shop doesn't use a DynoJet. The guy types the axle ratio into the computer. I got the same results with 3.08:1 and 3.73:1 ratios. Of course, most guys change to synthetic lube when they change ratios. I changed the 3.08s to synthetic before the trip to the dyno.
Car: ws6
Engine: ls1
Transmission: m6
Ok how much of a change will it show. man this thread has confused me even more lolzz sorry but I really didnt understand the last sentence of your previous post. Did u mean a lower gear car will dyno higher pretty much?
Car: ws6
Engine: ls1
Transmission: m6
I just read on a mustang forums that the gear ratio is entered into the computer. So it shouldnt effect the hp/tq reading.
My Optimal Shift point analysis from a Dynojet:
Same car, same dyno, same motor, same tune. The only thing that changes is the drive ratio from the gears. Dynojet's have a calibrated drum, and can't correct for all the nuances of gear changes.
Car: projects.......
85MikeTPI - you are 100% certain that all atmospheric variables were the same(temperature, pressure, altititude) and that the car was tied down exactly the same way with exactly the same tire pressure? - and the same SAE correction factors were used? If so, then either your dyno opertator is doing something wrong or he needs to have some refurb work done on his equipment.
A dyno reads wheel speed and engine rpm vs a calculated resistance(load). Gearing plays no part.
I'm actually surprised that this was such a mindset. I've been doing dyno tests for years and never knew there was such faith in dynos.
I've done similar tests in the past using different motors, different dynos, different operators, etc., all the same result.
These pulls were made within minutes of each other, no variables..
I can't see needing to change the shift point due to gears. The head-flow, intake, and cam size will always dictate an engine's peak power rpm and the optimum shift point will always remain within a few hundred rpm of that, no matter what gears are in it.
My only faith in a dyno is that it is a great tuning tool. We don't race dynos for a reason.
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Obviously, gears have nothing to do with the horsepower an engine makes. The question is whether a dyno would read a different horsepower with only a gear change (assuming all other variables are the same).
Assuming the dyno is properly calibrated and used- Absolutely not!!!
The dyno doesn't "care" what gear is in the rear. Or what gear the tranny is in for that matter.
A dyno simply calculates the horsepower based on the HP=torque x RPM/5252formula. End of story. If the gear is lower, yes more torque is delivered to the wheels, but the RPM of the wheel is less. Think about above constant in terms of wheel RPM and engine RPM.
In the case of the dyno that simply spins a big drum, after a gear change the drum would accelerate faster, but to a lower speed, therefore regestering the EXACT same horsepower at the wheel. The program simply associates the horsepower measured (at the wheel) to the engine RPM monitored when the wheel generated THAT amount of power.
If a dyno "sees" more power somehow it must be attributed to something else (besides conditional changes) such as programming in the software or possibly operation manipulation, intentional or otherwise.
There is no additional horsepower so the dyno cannot say there is.
UltRoadWarrior9
09-02-2015 08:24 PM
