700R4?
Old 03-24-2009 | 10:45 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
700R4?
I have a question about my transmission. I am sure this has been asked several times but I have searched to no avail. I have an 89 RS with the 2.8. DOes anyone know what auto transmissions were offered that year? What I am wondering is do I have the 700R4?
Old 03-25-2009 | 01:55 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 700R4?
Yes, the 700R4 was first offered in 1983 and became the only automatic available starting in 1984. That includes your '89. But you have a V6 version of the 700R4, which has less beefy parts inside it, and a different bellhousing bolt pattern compared to the V8 version of the 700R4.
Old 03-25-2009 | 03:56 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: 700R4?
Thanks for the info. So if I planned to rebuild it I could get one from a v-8 and put my bell housing on it? Then have a beefier trans behind the v-6.
Old 03-26-2009 | 01:34 AM
Kevin91Z's Avatar
Re: 700R4?
The bellhousing on a 700R4 is part of the trans. It is not removeable like on a manual trans.
You can build up a V6 700R4 to have the same strength as a V8 model.
Old 03-27-2009 | 10:12 PM
RS_PLUS's Avatar
Car: 92 RS Camaro
Engine: 350 TBI
Transmission: Killer 700R4
Axle/Gears: 373 Posi
Re: 700R4?
I build these things everday Just like KEVIN91Z said you can beef up the V6 pretty easily. The input sprag and low reverse sprag are smaller, has less clutches in the 3-4 clutch pack, some really early ones had one less in the reverse input clutch too. Anywayz you can do about anything you wanna either way. Good luck man!
Old 04-01-2009 | 11:57 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: 700R4?
Thanks for the info. This is a great forum!
loud91rs
10-05-2015 10:05 PM
92projectcamaro
09-29-2015 07:07 PM
IROC ZELLER
09-29-2015 03:00 PM
indygene
09-26-2015 11:21 AM
6998poncho
09-25-2015 02:56 PM
Quick Reply: 700R4?
