Th400 short tail or long tail?
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
Hi im doing a pontiac 455 engine and th400 tranny swap into a thirdgen and i was wondering what is the difference between long tail and short tail th400's? pictures would be nice.
Thanks, Gary
Thanks, Gary
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Th400 short tail or long tail?
I'm not sure there is such a thing with a TH400. All the ones I've ever seen have a short tailshaft.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Didn't you get one with the engine? You can't run your third-gen's original driveshaft, so you can use either short or long. Long has the benefit of a shorter driveshaft, reducing unsprung weight. But short, if you already have it, has the benefit of you already having it, if you do. (redundant, huh?) And if you're making enough power to need a TH400, then you're making enough to need a driveshaft with a stronger tube than just having your stock one shortened and fitted with a TH400 slip yoke. If I'm not mistaken, the Hurst kit will work with either, if you wanna run your stock torque arm. The BMR Fabrication torque arm is a good bit shorter, so again, you could go either way. As for the mounting, no difference. Doing a driveshaft loop may prove easier with a short-tail. If you want to add a GearVendors OD, you'll need the short tail. Sorry, no pics.
Axle/Gears: Posi.
i think its a short tail. i searched it and mine looks like the short tail. i know i cant run the original driveshaft im going to buy a driveshaft from spohn.
Axle/Gears: Posi.
ok ya its def. short tail ill try to get pics to confirm.
Axle/Gears: Posi.
Are they better than the long tail? im eventually going to make it a street/strip car.
florida_gators
Exterior Parts Wanted
09-07-2015 07:19 PM
rudolphschenker
09-04-2015 02:41 AM
400, difference, long, longtail, mounting, nose, shaft, short, tail, th400, tranny, transmission, transmissions, turbo, vs
