TKO List of parts
Car: 1989 Pontiac Firebird FORMULA
Engine: Rebuilt Chevy 350 in 2007
Transmission: 5 Speed Borg
TKO List of parts
1989 firebird formula 5 speed
I wanna put a TKO 600 5 speed in my car it is already a 5 speed, can someone give me a complete list of parts i well need to install the TKO 600 i just wanna make sure i have everything to be able to drive away and not have a firebird held up with a half installed tranny.
THANKS
THANKS
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: TKO List of parts
I assume, by asking for a list, you're going to round up the parts rather than just order a swap kit. That being the case, here're a few things to get you started. Slip yoke. Might also require a conversion-style u-joint if your driveshaft is the correct length. But as you're going to a TKO600, you must want more torque capability than the T5, so it might be well to just get a stronger driveshaft. Unless you need more than a 4.10:1 rear gear, I'd suggest 3" O.D. tubing. 3.5" is a tight fit with a torque arm. 0.083" wall-tubing should suffice, 0.095" is probably overkill. And if you decide to have one built, order it with 1350 yokes at both ends. IIRC, the slip yoke for the TKO600 takes a 1350 u-joint anyway. Unstall the engine, bellhousing and trans. Be sure the rear axle is what is supporting the rear of the car, not jackstands to the underbody. Slide the slipyoke all the way in, then back out one inch. Now you can measure the center-to-center (of the u-joints) for driveshaft length.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Oh yeah, almost forgot. If you have a driveshaft made, and are still usung your original axle, you'll need to use a conversion style u-joint back there. There are NO 1350 yokes for either the 7.625" or 7.75" axles.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
depends on the tko you get, you need an adapter plate for the bellhousing, ford c6 style slip yoke, crossmember kit for a tko, or adapters, special pilot bearing, it's best to just order the f-late kit from fortes.
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
http://www.fbody.com/tech/details.cgi?id=13
1992 Trans Am
05-10-2023 07:19 PM
LT1Formula
20
11-14-2015 12:02 AM
