is 3-5mm over the cross-hatch on the dipstick too much tranny fluid?
Old 06-04-2001, 08:22 PM
86Trans Am's Avatar
If so, i guess i'll be letting some out.
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old 06-05-2001, 07:34 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Don't worry 'bout it.... The dipstick isn't that accurate anyway and 3-5mm's is nothing bad. 3-5 inches is bad.
Old 06-05-2001, 12:15 PM
86Trans Am's Avatar
I drove it a little and rechecked and it actually is about a centimeter, i just dont want it getting too hot or whatever and blowing all over the engine...
any other comments?
thanks
1986 Trans Am
305 TPI
Old 06-06-2001, 12:59 PM
86Trans Am's Avatar
come on now, someone has to know, yes or no.
1986 Trans Am
305 TPI
Old 06-06-2001, 08:30 PM
JoelOl75's Avatar
You could get one of those fluid pumps and siphon some out from the dipstick tube.
Another trick is if you have access to air and have a blower nozzle is to take a length of vacuum line and about an inch from the end put a slice in it and jab the air nozzle into the cut. This will start a vacuum to pull the fluid up out of the dipstick hole, just watch because it could blow all over the place.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
NZKnight
10-15-2015 02:47 PM
bjpotter
10-04-2015 07:48 PM
meeklay812
10-01-2015 03:46 PM
mfp189
09-27-2015 09:25 AM
Quick Reply: is 3-5mm over the cross-hatch on the dipstick too much tranny fluid?
