TCI Governor recalibration kit
Car: 1983 camaro
Engine: 383sbc
i have freshly rebuilt 700r4 but it shifts out of frist gear at 4500rpm. I was told i need to use the governor recalibration kit has anyone used it and what weight and spring should i use i have 2400 converter and 410 gears
also how hard is it to do and can it be done in the car
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: TCI Governor recalibration kit
easy to do,
can be done in the car by removing the small cover on the drivers side (not the passenger side!!!!!!!!)
takes approx 30-40minutes to complete, jacking up the car and all.
if you jack it from the rear hardly any atf comes out if any
can re-seal the cover with silicone
Car: 1983 camaro
Engine: 383sbc
Axle/Gears: 3.36
heaviest weight makes shifts earlier make sense?
grind weight off or take weight off to shift later(like your 4500 rpm)
Car: 88 GTA "Cocaine"
Engine: 350 tpi
move one up from stock
I just put the corvette gov in and I am way more happy than my adjustments with the wieghts and springs
I also wanted to tune it down a bit
Car: 1983 camaro
Engine: 383sbc
im looking for it to shift at 5700 to 5800 that is where my car makes the most power
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
700, 700r4, bm, govenor, governor, governot, kit, kits, r4, recalibration, spring, tci, trans, transmisiions, transmission
