Aluminum Vs. Steel drive shaft difference
Car: 89 Firebird
Does any one know the weight difference between the factory steel and factory Aluminum drive shafts?
Or what is your best guess?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Aluminum Vs. Steel drive shaft difference
10 pounds? They're not very heavy.
For a high HP vehicle, you're better off with an aftermarket driveshaft. The factory aluminum shaft isn't very strong.
My race car has a 3" x .083" steel driveshaft with 1350 yokes.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This, which should provide an idea, from a search:
16 lbs - Stock steel LT1 driveshaft
12.2 lbs - 3rd gen aluminum 1LE driveshaft
11.5 lbs - Stock aluminum LS1 driveshaft
JamesC
JamesC
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
1987, aftermarket, aluminum, alumminum, ans, body, difference, drive, driveshaft, iroc, shaft, shafts, steel, vs, weight
