What gear ratio is in a Astro van rear?
I just bought a Firebird. The guy said it had a 4.11 posi in it. He lied. But anyway. Anyone know the ratio? Thanks.
Car: 82 camaro SC
My parents old 88 has 3.08 gears. You could probably order what you wanted, so it will vary. GM made some astro vans with a 4 cylinder, I would guess they had deep gears. S10's are another excellent source for used gears.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Ok, I just pulled the cover and here's the numbers I got off the big gear. BM OR 3M-14085339-12:41-7-5/8-12-84 do these mean anything? Is there a gear ratio in there somewhere Thanks.
Brad...
Brad...
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I learned how to figure this from one of the guys here. The 12:41 is the amount of teeth on the gears. 12 on the pinion and 41 on the ring gear. Divide the ring by the pinion and that gives you 3.4166.... That would be a 3.42. The 7 5/8 is the diameter of the ring in inches, and the 12-84 means it was cast in Dec. of 1984. I think the rest is just the casting #, I'm not sure on that. The 3M is probably that it's a 3 series carrier, but I'm guesing, so don't hold me too that.
Cool huh? I learned so much from this website already, my brain is boiling.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited June 03, 2001).]
air cleaner
-B&M TransPak
-Jet Stage2 Chip
Yup. This site is the BEST. I Did a search and found out what they were and what numbers to divide. I should have did the search first. But oh well. This is just too coool. Thanks.
Brad...
Brad...
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
