9.010 Deck Height effect on Valve Geometry
The standard deck height on a #010 block is 9.025. I had mine decked to 9.010 or .015 less.
I've got Comp Cams 4130 standard length pushrods. Should I be concerned with rocker roller contact with the valve tip?
The engine is done but still on the stand with valve covers on. This is just one of those things in back of my mind that's bugging me. (Also Distributor to cam gear centering).
This was not a total after thought as I did roughly eyeball it after setting the lifters but I did not Blue the tips.
Thanks in advance. I like to sleep nights.
Sorry! Wrong board.........*
Engine: SBC 4-bolt #010, Balanced 383 Eagle crank assembly, 4340 crank and 4340 H-Bean 6.0 rods with SRP flat tops.
DART IE 200/72cc heads (10.1:1 C/R) with Harland Sharp 1.5 full rockers and Comp Cams XE274H (230/236 .487/.490 110LSA 1,800-6,000 RPM).
Edelbrock RPM manifold with 750 (VAC/Electric) Holley.
MSD Pro-Billet (Vac) with 6AL box.
My best guess (Dyno 2000) is about 400HP and 430TQ??
[This message has been edited by Changa2 (edited May 27, 2001).]
Hotrodboba400
12-10-2019 07:07 PM
355tpipickup
09-13-2015 11:35 PM
