ED is the Rear cast Iron or cast steel?
Im about to weld the tubes to the rearend. Im guessing its a cast steel if you were able to weld it with 7018 rod
not sure but i believe it's cast steel. it does weld very easily with 7018 or steel mig
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Welder Buddy Of Mine I was asking about welding the Tubes Told me It was Cast iron, Looks like cast Iron To me.
But again, Im Far from an expert.
Ede, welding cast iron To cast Iron, How easy is it ? Cause Ive Got a Turbo flange and a strait Six Exhuast manifold that need some love...
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
not to put down your welder buddy, but i'd bet a dolalr or two that it's cast steel. since we're on the subject, i have degree in quality engineering, am an AWS certified welding inspector, have or am certified to mil-specs, ASME, and AWS. welded since i was 16 and am older than dirt now. i ahve welded a boat load of rear ends, tubes to center sections and for the most part have used 3/32 e7018 and on a few steel mig with no problems. i like to use 2 passes when i weld, mostly from welding pipe and not wanting leaks, but i 2 pass the axle tubes.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
junkcltr
08-02-2019 11:12 PM
ambainb
04-25-2016 09:21 PM
sailtexas186548
01-19-2016 12:21 PM
