Transmission mount
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Transmission mount
Ok the **** hath finally hitteth the fan . I was trying to change out my transmission mount and the bolt that goes through the crossmember started rotating freely inside the transmission mount. The nut is stuck really bad so it won't come off. So I tried pulling off the whole crossmember. The bolts on the wretched thing were so tight they busted my ratchet handle. Now I have no way of getting the mount out of there. The nut on the bottom bolt is halfway loose, making the situation even worse than before. I can feel the transmission jumping around over rough roads. Can I have the offending nut/bolt cut off and drive back home (about 3 miles) without the transmission solidly anchored to the crossmember?
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Momo steering wheel
Flowmaster muffler
i'd say yes, if you have a broke mount it isn't tied down anyway. take it easy if you drive it. if it were me i'd try to find a torch or grinder i could use to cut the bolt off. i'd use a ES poly mount instead of an OEM type mount.
-=ICON MOTORSPORTS=-
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
See if you can get a hack saw and saw it off. Shounldnt take to long with a sharp blade.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
I see this was posted quite a while ago, but i would have suggested some liquid wrench, and an open ended wrench to remove the bolt, while holding the bolt with some lock-jaw pliers.
Joe
86 IROC TPI 305
700-R4
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
Next mod = trans-go shift kit
Joe
86 IROC TPI 305
700-R4
K&N Air filters
Dyno-Max cat-back
Car: 1994 Trans Am
Engine: 5.7L LT1
Hey Joe, thanks for replying. I took the car to my exhaust guy the next day and had the entire thing cut off with a torch. Yeah, it was fun watching that b@stard melt and fall to the ground!
'88 IROC 305 TPI
Crappy 700R4 slushbox
Gutted airboxes
180 degree T-stat
Momo steering wheel (gotta luv it)
Flowmaster muffler (puke)
Taylor SpiroPro wires
Accel cap and rotor
Ported plenum
Kills: '94 Z28, Olds Aurora V8, bunch of Mustangs, T-birds, ricers, and others who assumed a 12 year-old car would be too slow.
'88 IROC 305 TPI
Gutted airboxes
180 degree T-stat
Accel cap and rotor
Ported plenum
theshackle
08-23-2015 03:49 PM
