what is ur converter's slippage?
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Testing a theory out here...just want to see with my own eyes. I want to see what different torque converter companies have for slippage with different STR's. I realize that the higher STR, the more slippage I will have up top. Just want to see others
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: what is ur converter's slippage?
I have a 6000 stall converter with a calculated slippage of 4% based on 1/4 mile results.
You can have a 10" converter with 3500 stall and a 8" converter with 3500 stall and they'll have different slippage.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
From what I've seen, 10% is the standard slip at peak hp rpm in drive. My current one is at 10%, as have 2 others at different power levels except for when I was overpowering one of them it was slipping more like 22%.
Car: 92 Camaro
Axle/Gears: S60 373
wow 22% thats a bit much
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
That was a sure sign I was overpowering the converter. It was a 3500 stall made for my motor, but then I put the blower on to add 200-250hp. It was hard to shift it right since it would only drop 500-600rpm from each shift, and first gear was almost useless since I'd have to go into 2nd before the 60 foot. But like I said, all of the other situations I've had the slip is 10%.
Thirdgen89GTA
11-26-2015 11:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
