detent cable problems
Car: 1989 firebird
does anybody else on here have problems with there detent cables adustment changing when your at wide open throttle on a tbi car.i have this problem on my 89 firebird and my 88 chevy truck any input or suggestions would be appreciated.
Car: projects.......
Re: detent cable problems
I'm guessing both these apps are factory linkage and cables?
The detent cable is supposed to be fully extended at WOT. If it is not fully extended, but is adjusting anyway, then the locking mechanism on the cable is weak. If you are trying to change your shift points by adjusting the cable, you can/will damage the transmission. The tv cable controls line pressure inside the trans, which in turn varies the pressure applied to the governor, thus varying the shift points. To tune the shift points you have to change the weights and/or springs in the governor.
If these are non-factory linkage, Superior makes a TV correction kit that utilizes a small spring a clip to increase the cable tension at part thottle, but allow for travel to WOT w/o over extending the cable.
9192camaro
16
02-03-2019 12:21 AM
db057
08-11-2015 10:11 PM
