What is this banging noise
I just bought an 83z28 and I am pretty sure that it was beatup from the previous owner. I was more interested in the body and did not care about the motor as I have a 350 to replace it with. I had to have the car trailed to my place as it was not safe to drive. I replaced the tires, replaced shocks, got the motor to run and then I took the car out for a test drive. As I acccelerated heard a medalic like sound and also when I took my foot off the gas pedal. the sound was like a hammer striking medal. The is a tranny is a manual. Not sure whaqt the noise was I did not get out of fisrt gear. It happens in 1st and reverse.
any thoughts?
any thoughts?
Car: 4
Engine: 6
Transmission: 5
Sounds a bit like a wasted U-joint, or something under the car loose such that the drive shaft can hit it.
ICON Motorsports
ICON Motorsports
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Gman,
It sounds like your transmission mount is shot.You wont be able to see just by looking at it but when you unbolt it from the x member and transmission chances are it will fall apart
cheers
powermite
cheers
powermite
Car: 1983 Z28
Transmission: WCT5
this is probably NOT your problem, but one that I had, so you might check it out. when I got my '83 it seems some monkey had replaced the gearbox with a junkard unit. when they shot the top bolt for the torque arm mount they stripped it out. this let the torque arm come out of its mount and hit the tunnel. a very disconcerting noise with any torque change.
just one to check out
Clem
Clem
Get a polyeurathane replacement if you can, I highly recommend it.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance Soon: Edlebrock Intake & TES
--Steve S--
UltRoadWarrior9
04-28-2020 10:39 PM
sjorgens
10-01-2015 07:54 PM
