driveshaft very close to exhaust
Car: 1992 camaro rs convertable
Engine: 350 tbi
Transmission: auto
Axle/Gears: 3:08 posi
i just installed a aluminum d/s in my 92 camaro,its very close to the exhaust,anyone have this problem?
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: driveshaft very close to exhaust
Have you driven the car yet? You'd probably hear it rubbing while you were driving if it did. After you drive it, crawl under the car and it will be obvious if it did rub.
Unless it hit's it your fine.
The only way you would have a problem is if the u-joints broke, or the exhaust hangers let the exhaust swing into it.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
That would be normal...
Engine: 350 tbi
Transmission: auto
i havent driven it yet cause snow,sand,rain,winter...but if it dosent touch while the car is not moving how about when im going 60mph?
Car: 85 Camaro Z/28
Transmission: built 700r, B&M shift kit
i think the only time you might could encounter a problem would be if you hit a bump or something that pushed the driveshaft into the exhaust or something of that sort
That pic has way more room than mine...and I have NEVER had problems with it.
If yours doesn't touch, rub or make noise when driving...you're good.
ambainb
04-25-2016 09:21 PM
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
TheTraut88
09-07-2015 05:22 PM
