th400 info ASAP!!!!!
I need to know what all i need to run a th400 in my 88 camaro please help with everthing!!!!
1988 Camaro RS T-Tops white. Was 2.8 now a mean 406 sbc
(mods)
750 Edelbrock carb
Performer RPM intake
Comp cams Magnum @.50 230-230 lift 480-480
Flowtech 1 3/4 headders with glasspacks for true duals and thats it for now
E.T. 1/4=?
will post when race season starts
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
91-92 ground effects
b&m pn 30299 will fix all your problems ,except the drive shaft, not sure if it'll work with the 400 without being shortened.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I used the Hurst T400 kit from Jegs. ~$125. After you get the tranny installed, then measure for the correct length drive shaft. I used an old T400 Chevelle drive shaft and had it shortened and balanced ~$100 and the correct u-joints ~$50.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Miles
88 427 Camaro
www.koolmeister.com
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Spohn Performance at the top of this screen. One-stop-shopping for the best pieces you can possibly get.
Well, you'll also need to wire a kick-down switch, which mounts behind the throttle arm (Summit), with ignition-switched power.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
Engine: LS1/LQ4
Alright, you'll also need to do something about the shifter. Great time for a B&M console MegaShifter or Hammer.
yeah you're right aboutthe b&m being for th350s. sad thing is i have a old box laying hear and i could see it well enough to read what it said on it. man soon as you hit 40 your eye sight starts to go. sorry for the wrong information.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
3rdgenparts
05-21-2016 11:50 PM
darwinprice
17
10-11-2015 11:51 PM
Linson
10-01-2015 09:50 PM
