9 bolt axle removal...Tips?
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Hey im in the process of servicing my 9 bolt (new axle bears and shimming the posi). I have the four bolts holding the axles in removed. Is there a trick to getting the axles out? I heard slide hammer but i dont have one. Anything else that can be used in a pinch?
Engine: 355 TPI
Re: 9 bolt axle removal...Tips?
Hitting outwards? Your talking hitting right on the back side where the lugnut studs are? I still have the dust shield on as well. How the hell does that come off? Is it welded on?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I used an Axle puller that I borrowed from Autozone. Makes it alot easier. Make sure you have the backing plates unbolted...
Engine: 355 TPI
I just have the 4 bolts unbolted. I didnt see anything else that could come off. By backing plate do you mean the dust shield or the part that i already have undone?
Engine: 355 TPI
You must have gotten lucky then. I pounded for awhile but it didnt budge. I was using a long bolt that was just a bit smaller than the holes that mount the backing plate and axle in. I stuck it through those holes so i could get a nice square hit to the backside of the wheel mounting area of the axle. Nada. Im going to rent a axle puller from autozone as someone above suggested and make life easy on myself.
Engine: 355 TPI
So nice to have the right tools. Just updating this post to let everyone know i borrowed a slide hammer from my mechanic (good to know people) and they came right out in two big blows. Now on to my other thread about posi rebuilding..........
dbrochard
10-03-2015 12:43 PM
rudolphschenker
09-04-2015 02:41 AM
UltRoadWarrior9
09-02-2015 08:24 PM
