2.73 to 3.23 swap, 700r4 Speedo Gear Help
Old 12-07-2008 | 07:03 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
getting rid of the crappy 2.73 and going to 3.23
need to know what speed gears to go with, and how to swap them out. for some reason it seems to take an act of congress to get anyone around to even do it, they like use an aftermarket tuner.....ITS NOT A NEW COMPUTER CONTROLED P.O.S.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! oh well you are going to have to take that to the dealer
i know its been talked about on here but i cant get the exact anwsers im looking for in my search
Old 12-07-2008 | 07:13 PM
89RS_82Z's Avatar
Re: 2.73 to 3.23 swap, 700r4 Speedo Gear Help
also is there anyway to replace just the driven gear and not the drive gear
tire size is 245/60/15
i should have a red driven now, and a red drive....... would a light blue driven work close enough with the red drive
Old 12-07-2008 | 10:00 PM
89RS_82Z's Avatar
bump
Old 12-07-2008 | 11:16 PM
performabuilt's Avatar
do a search on yahoo for speedometer world you wil fine what you need there
Old 12-07-2008 | 11:34 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
of the rear end gears of the speedo gears? because with the rear end gears you cant do that, since theyre made as a set, and will chew each other up if you use mismatched ones.
Old 12-08-2008 | 09:02 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You need the blue 18 tooth drive gear PN 8640518, and the dark gray 44 tooth driven gear, PN 25513051 for '89-'92 style speedometer, or 9780470 for '82-'88 style speedometer. This'll have you dead-nuts perfectly accurate with 3.23:1 and 245/60R15s
Old 12-08-2008 | 08:59 PM
89RS_82Z's Avatar
ok so we got that figured out, how do i get the drive gear off, i have never done this yet
Old 12-09-2008 | 10:46 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There are any number of ways to break the old gear off, the real trick is to install the new gear without cracking it. Getting it warm will help.
Old 12-09-2008 | 03:32 PM
RedLava's Avatar
Car: 86 z28
I went from a 2.73 to a 3.27 rear end you do not need to change the drive gear. The new gear I got was dark green, but I do not remember if it was off by plus or minus 5 percent of my speed. You will need a new carrier for the driven gear though.
http://www.partshp.com/speedometer_gears.htm
I got my new to me aluminum housing from them. Even though it says they are out of stock on the used ones give them a call and see if they just didn't update there site.
Old 12-10-2008 | 11:18 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You need exactly what I posted. Nothing more, nothing less. I just did this exact thing to my '82 Camaro, with the same size tires as you. It has the 3.23:1 axle from my '84 Trans Am, and a '91 700R-4 running the '82 Speedometer cable. Ignore red lava on this particular one.
Old 12-11-2008 | 12:27 PM
RedLava's Avatar
Car: 86 z28
44/18= 2.444
42/17=2.471
2.471/2.444=1.011
Thats a 1 percent difference between the gear combination that I listed and the one you gave. Save your money and just use 42 tooth
Here is how to replace the driven and the drive gear
https://www.thirdgen.org/speedogear
Old 12-16-2008 | 12:24 AM
darkride86T/A's Avatar
From: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
The tranny that I put in my Bird was from a '91 Z28 w/L98 and 3.23 gears. It had the green driven gear but the drive gear was the same red one that was in my original '86 700R4 that came out of my car. The Bird still has the 2.73 open diff. All I did was swap in my 2.73 driven gear into the new tranny and that's it. I'm running 245/50-16's and my speedo is dead accurate. It was dead accurate when I was running the stock 215/65-15's.
Old 12-16-2008 | 10:33 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i usually call local gm dealer if u get someone that knows anything they can help u most of the time l
Old 08-03-2023 | 06:09 AM
81malibuwagon's Avatar
Hello! I have a question for you transmission heads. I used to have a 305 iroc z 1987 and used the 700r4 for a 1981 Malibu wagon. The rear I swapped in is a 2.73posi. as you can imagine the speedometer is off. I was wondering if anyone knows which speed gear combination I need to correct the issue. Up to 40"mph" the km/hr is correct and goes off after that.
Old 08-03-2023 | 08:48 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Part of the issue...we don't know what drive/driven gear combination you have but once you determine that, you should be able to figure out what you need.
https://www.tciauto.com/speedometer-gear-calculator
camaro11j
09-19-2018 08:49 AM
Orr89RocZ
04-25-2016 08:28 AM
draco
10-04-2015 09:25 PM
hectre13
08-26-2015 08:17 AM
Quick Reply: 2.73 to 3.23 swap, 700r4 Speedo Gear Help
