Hey I can shift into OD at WOT...
Old 03-23-2001, 09:20 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
it turns out that if you cut your speed limiter. Then you can shift the car into OD at WOT. I did it last night while racing up againts a TT 300ZX. I didn't think it would shift. I was going to let off the gas and then shift it. Like how it normally is. But I just keeped flooring it and then shifted into OD and it shifted. Oh yea and about the race with the TT I keeped up but I still lost. He was slowly pulling from me.
Chris
91 RS 305 TBI
Eternal Rev
15.1@94mph (really bad traction and wheel hop)
Old 03-24-2001, 02:48 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You must have got a 'fluke' tranny or one out of a corvette, fib'd, cam that had the revised kit already installed....
What rpm did it shift @?
Old 03-24-2001, 09:57 AM
GTA
GTA's Avatar
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Can you guys please explain what you mean
when you say the car will not shift into
od at WOT, My 92 GTA with 700-r4, and B@M
shift kit shifts into od at WOT and stays
there untill I lose my nerve and let off
If I remember right the 1-2 shift happens
at about 4000 and the rest of the shifts
are all just around 3500 or so all this happens with my foot planted to the floor
in od,once it shifts into od the tach just
keeps on going up (no searching for 3rd)
Oh well I guess i'm just lucky. GTA...
Old 03-24-2001, 10:39 AM
82camaro's Avatar
Car: 82 camaro SC
od at WOT
Easy, it won't shift into overdrive at anything past about 2/3 throttle(WOT).
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old 03-24-2001, 02:49 PM
mostafa3k's Avatar
kinda stupid isn't it? I guess the speed limiter protects that, but what if one were to hit 140 and decide to floor it? It would kinda suck for your car. An upshift valve should protect that as well as give you another 33% throttle for higher speeds.
Old 03-24-2001, 11:30 PM
SUPER-SPORT-CHEVY's Avatar
Wierd i've driven vetts that kicked out of od at 85 hmmmm. i know that b&m makes a kit 40$ that keeps it in od until 3/4 throttle.
85 Camaro RS T tops 350/350, stealth intake. holley street avenger 670. ported 58cc heads. comp magnum 270H cam,Crane 1.6 roller rockers,edelbrock accu-drive, MSD 6 series ignition on HEI, K&N extream air cleaner, true dual exhaust with 18 inch glasspacks.
82 Firebird 305/250 action plus intake, accel distributer with ccs 8mm wires foam air filter.
The only "cat" i have uses the litter box
Old 03-25-2001, 12:03 AM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
I'm not trying to be rude but stay away from B&M's TV Aluminum sleeve thats sold in Jegs or Summit. A TRUE P.O.S.
The only kit that B&M sells that allows a TRUE 3-4 UPSHIFT and NO DOWNSHIFT from overdrive is #70249. It is only available from B&M directly. Or get the GM Kit #8673948
1992 Trans Am
05-10-2023 07:19 PM
Fox118
Members Firebirds
111
01-26-2016 07:17 PM
PestilenceIV
09-05-2015 04:37 PM
tecustomz
08-16-2015 02:28 PM
gwade12
08-08-2015 08:17 AM
Quick Reply: Hey I can shift into OD at WOT...
