chooseing stall
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
chooseing stall
i made some research but i'm not quite sure if may conclusions are right.
im running 383 HSR with 30th injectors, edelbrock performer 60859 heads and CompCams cam spec:
Basic Operating RPM Range: 1,800-5,800
Duration at 050 inch Lift: 224 int./230 exh.
Advertised Duration: 276 int./281 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.503 int./0.510 exh. lift
Lobe Separation (degrees): 112
tranny is 700r4 with B&M TransPak
which stall should choose ?? 1800 as teh beginning of operating range or bigger ??
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: chooseing stall
With your combo, I'd say you have enough low-end torque that a 3000 stall would be looser than you need, I'd start with a 2400-2500.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: chooseing stall
For street/strip, you want a stall about 500 rpm past the beginning of the power band. 1800 + 500 = 2300. 2500 will probably still work fine based on the advertised duration. I wouldn't recommend going over 3000 rpm.
For all out race, 1000 rpm over where the powerband starts.
Re: chooseing stall
as we do not have dragstrips in poland this is mostly street car, so ill try with 2300, thanks for help
darwinprice
17
10-11-2015 11:51 PM
HoosierinWA
10-07-2015 10:15 AM
