Bought SLP takeoff,I swear it is 26 spline.Will this work in my 7.5,1992 3.08?
Bought a SLP take off and it is 26 spline(must be the "OEM" unit).
I need to know if I can retrofit this and 3.23 gears with no problems.
Comments?(VHT is getting expensive so are new Eagle GA,s on the right rear!)
1992 RS
305 LO3
350 injectors
T-5
Crane Compucam2031
ported stock intake
work on throttle body
Edelbrock headers w/3" outlet
Edelbrock valve springs
Cloyes true roller set
Roller tip rockers
no air
no power acc.
2 chamber Flowmaster w/Dynomax intermediate
Poly lower control arm bushings
14.5@95mph
1992 RS
305 LO3
350 injectors
T-5
Crane Compucam2031
ported stock intake
Roller tip rockers
no air
no power acc.
14.5@95mph
Car: 88 Firebird WS6
Yes, the housings are the same, you will just need new axles (or out of the junkyard).
If you have rear discs and pull the axles out of a drum car you will need to have the o.d. turned down to fit inside the rotor.
Those two extra splines don't seem to be that much, but in actuality they add considerable strength. I know going from 28 to 31 splines adds something like 31% more strength. It's a shame you have to backtrack on this, but I only have 26 spliners and added an auburn pro-posi and richmonds w/ a girdle and never had a prob. Trannys seem to be the downfall of me, but then again I never ran anything stickier than a drag radial. True slicks would probably trash it. Then again the stock axle splines would probably chew off before anything. My friend has a weak kneed LG4 with 3.08 and open diff and blew the spider gears out first (doing a one-wheel spinnin' breakstand)
If you do change the axles I'd recommend at least changing the end seals if they are old. Nothing like gear lube slung all inside your wheel over a cheap part.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
'88 Camaro RS 2.8L
1 Post
Car: '85 IROC
The take-off diff can *NOT* be 26 spline. Count them.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Posi, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Serious, If it is indeed a 26 spline where the hell did you get it ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
1 Post
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
A SLP takeoff 26 spline carrier should bolt in. I was told it would bolt into my '91 10bolt in my GTA with no modifications. Whats going on here?
'91 GTA:
www.fbody.com/members/91WS6GTA
'91 GTA:
Since 1990, all GM f-body rear ends are 10-bolts with 28 spline axles. Since that posi was "taken off" a late model f-body, it has to be 28 spline axles. Or they sent you something else instead of one taken off a late model f-body. Or you're counting wrong.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
SLP do NOT sell a 26 spline take-off posi unit. I bought a take off unit last week and i know its 28 spline. They even made sure i knew how many splines on the axle i would need.
1 Post
Car: '91 GTA
Engine: 402ci LS2
SORRY guys! I meant 26 spline! I'm wanting one, but SLP said that '91's could have 26 or 28 spline axles. What the hell is going on?
'91 GTA:
'91 GTA:
Engine: LS1 / LS3
Umm, they SHOULD be 28 spline by 91. Don't say that they could be, i am about to pick up a 91 rear and i need the axles to be 28 spline! Luckily the guy checked and it is.
Pull the axle to check.. Its not hard and its a sure fire way to find out.
The disk brake equipped rear I pulled from a '90 5.7 IROC was 28 spline.... and the axles look like tree trunks compared side by side with the old 26 spline ones.... The drum rears I have seen are 26 spline. So depends on the rear.
86IROC112
09-07-2015 01:37 PM
knight72
08-10-2015 09:32 PM
