quick question full manuel VB?
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
hi,does that stiffen up shifts to the point were you can atleast chirp gears
Car: 1991 Camaro RS
Engine: 454
Axle/Gears: 2.73 open
Re: quick question full manuel VB?
Depends on the valve body. If it's a street car then get a good shift kit that allows you to hold the gears for as long as you want. You will want to go with a well known company such as transgo or B&M. Get one that has replacements springs, separator plate, everything. This way you have the option to throw it in Drive and go or bang through the gears and downshift on command.
I have a Transgo kit in my 350 and it will bark second. Don't know about third. I have 2.73s, no posi, and a Big Block though.
Car: 89 Formy
Transmission: A4
can i use my stock shifter with a reverse pattern valve body also?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just as long as you remember first gear is just off neutral and you need to pull the shifter back to go up the gears. To get back to neutral or reverse, you need to downshift through all the gears. If the shifter is bumped forward while driving, it will instantly drop down a gear no matter what speed you're driving.
Street cars don't need manual valve bodies. Manually shifting through the gears in traffic will become annoying quickly.
Car: 1991 Camaro RS
Engine: 454
That's what I was saying. You get the same effect with a good shift kit...you can downshift and hold gears however you like but you retain the automatic feature. Just be sure to get a kit that has this provision...
Car: projects.......
Manual vb's are very hard on trans internals for street use. Very few(none for a 4l60) retain the TV function, thus full line pressure all the time. This causes excessive wear & tear on the pump and the planetaries(overly aggressive shifts at all rpm).
Don't get the junk B&M "kit". Transgo and Superior are the only real kits out there.
All that said, I've never understood the point of chirping gears everywhere. "hey, look at me, my suspension/tires don't work".
Car: 89 Formy
Transmission: A4
ok guys thanks for your inputs..ill go with a transgo shift kit ..thx guys
Car: 1991 Camaro RS
Engine: 454
Ghettobird52
07-05-2024 11:18 PM
