LT1 T56 pairing with LS1 motor
Car: 1985 Pontiac Trans Am
Engine: 5.7L LS1 FI
Axle/Gears: 3.23 factory 9 bolt
I purchased a '96 Camaro T56 without realizing I couldn't just "bolt it on" to my LS1 motor (out of '99 vette). As many of you know the input shaft is too short. As well as the bellhousing is different.
My question is, how do I swap the shaft? I have had trouble founding a site, let alone a forum, that describes the changing of these shafts.
Engine: 5.7L LS1 FI
Re: LT1 T56 pairing with LS1 motor
Someone here has done this...
Additionally, will I need to shorten the driveshaft?
Engine: 5.7L LS1 FI
Nevermind, I found an article. Swapping these input shafts aren't as simple as swapping cams to say the least.
I'm putting my LT1 T56 tranny package up for trade for LS1 T56.
Includes: Trans, bellhousing, clutch, pressure plate, clutch fork, and flywheel. Out of 96 Camaro with about 60,000 miles
ambainb
04-25-2016 09:21 PM
1992 Trans Am
08-08-2015 08:16 PM
