700r4...no 3rd or 4th gear
Car: 86 camaro irocz z28
the other night i lost my 3rd and 4th gear while i was driving. it was acting wierd about 2 days prior to this, not shiftin right and just really strange. is there any possibility that all i need is a tranny service, or do i need to rebuild? thanks
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Re: 700r4...no 3rd or 4th gear
Check vacuum lines? I didn't have OD on my 86 cause I didn't have it hooked up to the right line (whoops!) hehe! But since you said it was acting up a little just prior it could be the more expensive fix :/
yea thats what im thinking. im doing a tranny service on it tonight for s***'* and giggles just to see if it helps, so who knows
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
basically just check if you have the correct amount of fluid and that its not burnt or brown, if it is change it. but it sounds like that transmission is gonna need a rebuild
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
No vaccum lines on a 700r4. check the fluid and drop the pan. Probably will find clutch material in it.
Iroc8t8
08-26-2015 08:14 AM
