Convert posi to nonposi?
Car: '89 Camaro RS
Engine: 5.0L 305
Transmission: 700-R4
Axle/Gears: 2.73 :(
How would I go about converting my 1989 RS from posi to non posi?
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Convert posi to nonposi?
You can change the whole rear axle or you can change the carrier inside. Changing the carrier would require a professional to set-up the gears correctly. Can I ask why you would want to do this?
Car: '89 Camaro RS
Engine: 5.0L 305
Axle/Gears: 2.73 :(
Plain and simple...I hate one wheel burnouts, plus the gears are only 2.73
Car: '89 Camaro RS
Engine: 5.0L 305
Axle/Gears: 2.73 :(
Dang, sorry. I have been doing everything *** backwards today.
Yeah posi would be what I wanted to convert to. I just want my tires to wear evenly instead of one bald one and one decent one
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
To convert to posi you need to find a posi carrier and gears to go with it. You can easily spend close to $1000 doing this when you factor in installation and everything if you use new parts. Used parts you can do it cheaper, but then you're spending a lot of money to install new parts. The point is it takes special tools and special skills to install new carrier and gears into a differential housing and you will have to pay a somewhat specialized mechanic several hundred just for labor unless you can get a fat hookup.
What IS easy is swapping entire rear axles. You can do this by yourself in the driveway in just a few hours. You shouldn't have too hard of a time looking around locally finding a rear axle out of a 4th gen Camaro Z28 or Trans Am. This is exactly what I did. Many of these cars came with 3.42 and 3.23 posi rear ends from the factory. Any 4th gen Camaro with a T56 6 speed has a 3.42 posi. With the exception of some emergency brake issues that you will have to figure out, the rear end from these cars is a direct bolt in. Expect to pay anywhere from $200 to $500 and don't pay more than that. Even $500 is pushing it. In addition to better gears and a posi, you will get disk brakes too.
Look for rear ends from an LS1 car, 98-02, but any car 82-02 will technically work.
or you could go with one of these
http://store.summitracing.com/partde...5&autoview=sku
Engine: 5.7L/350
On Probation
Engine: several
Transmission: none
Axle/Gears: none
But since he's also tired of the 2.73:1 gear, an axle swap makes sense. It depends on what price he can get, to his door, as they say. Around here, 4th gen posi rears run no less than $1000, so I'd get a 3.42:1 non-posi from a '90-'92 V6/Auto camaro/bird, and do the conversion locker, which with shipping and lube would run $400 on a $75 rear. These V6s came with the 28-spline axles, the 7.625" ring gear, and haven't been abused.
Car: 1985 Camaro Sport Coupe
Engine: Twin Turbo crate 350
Transmission: TH350
Axle/Gears: still workin on that
go to accuautoparts.com and buy a locker
Car: 1987 Black IROC-Z (SOLD)
Iwant my posi rear converted back to nonpsi rear. Rason, I can not afford the costs of both tire replacement. So I want only one tire to wear out at a time. Same thing goes for my 3:45 gears, shold i get get 2:73s?? I don't know anything about gears or rears.
Hotrodboba400
12-10-2019 07:07 PM
georgiaslim45
09-09-2015 08:12 PM
georgiaslim45
09-09-2015 08:11 PM
