Rearend/Options
Rearend/Options
Does anybody have a link where i can tell what rearend i have by the VIN. I'm gonna go under the car tomorrow and see if i can find the "G code" off the rearend, but i'm looking for a site or link that can list them all by VIN or "G code." Thanks again guys for the help.
Re: Rearend/Options
I also read somewhere that if the rearend has posi theres a rearward facing tab on the side of the pumpkin. This true? Thanks for your answer big gear head.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Rearend/Options
Yes there should be a tab coming off one of the pumpkin cover bolts if it is posi. This is only if someone hasnt been in there though as by this time most of those tabs are gone.
Car: 1987 Black IROC-Z (SOLD)
Re: Rearend/Options
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Rearend/Options
At this point there's no telling what's been done by previous owners, the easiest way is to compare rpm to mph, if your speedo is accurate.
With 245/50R16 tires, and the 5-speed in 4th or the 700R-4 in third, with the converter locked, here's your rpm at 55 mph.
2.73:1=1966
2.77:1=1992
3.08:1=2213
3.23:1=2323
3.27:1=2353
3.42:1=2457
3.45:1=2484
3.73:1=2680
2.73:1=1966
2.77:1=1992
3.08:1=2213
3.23:1=2323
3.27:1=2353
3.42:1=2457
3.45:1=2484
3.73:1=2680
Location: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
Re: Rearend/Options
My '89 Iroc has 2.73 gears(GU2) and posi rear(G80).
