Help! Reverse Lights Stay on w/B&M Megashifter
Old 02-08-2001, 06:48 PM
BlueIrocZ's Avatar
I have had my megashifter for a year now and it works great(other than reverse light problem). It didn't do this at first, 6 months later it started and now it seems to be slowly getting worse. When I shift it from Park to OD, the reverse lights stay on in OD. I have to drop it down into drive, then the reverse lights go off, then shift it back up to OD and then they will stay off. Now It has gotten worse where I have to drop it into second and then back up to my normal drive gears to get it to go off. Does anybody have any suggestions or have had a similar problem? Thanks in advance.
89' 5.7L TPI Auto IROC American Racing Torque-thrust 2 rims ,Ported Plenum,Accel/Lingenfelter Runners,
Flowmaster, high-flow converter, SLP headers, B&M console megashifter, MSD 6aL, airfoil, K&N's,Gutted airbox, Bosch Platinum +4, 8.8 wires,Accel Coil
Old 02-08-2001, 07:53 PM
Cosmik Debris's Avatar
You may have to readjust the reverse light switch which is attached to the side of your megashifter. There are two switches, reverse lights and neutral safety. The switch has probably moved.
Old 02-08-2001, 07:57 PM
BlueIrocZ's Avatar
how do I adjust it?
Old 02-10-2001, 08:51 AM
82camaro's Avatar
Car: 82 camaro SC
loosen the screws and slide the switch. You may also need to bend the small lever a little bit.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old 10-19-2011, 01:56 PM
cactusman92's Avatar
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
Re: Help! Reverse Lights Stay on w/B&M Megashifter
the same think is happening to mine but i think my switch is shot as no matter how much i adjust it nothing and there is alot of freeplay in it
Rakim_RS25TH
09-01-2015 04:07 PM
Rakim_RS25TH
08-27-2015 05:04 PM
Jae992
08-27-2015 09:07 AM
stalkier
08-21-2015 01:54 AM
stalkier
08-13-2015 12:59 PM
Quick Reply: Help! Reverse Lights Stay on w/B&M Megashifter
