SUPER delayed upshift cause?
Car: 87 GTA
At "granny" throttle....won't shift until 4500rpminto 2nd, 3800rpm into 3rd....
My first suspicion is...Time to rebuild the trans, right? Well, it's a 3yr old full rebuilt, 20,000 miles. Never raced (since I bought the car) and never had a problem until now.
When in gear, the clutch discs HOLD, zero slipping. Driving, maybe 10mph while still in first, if I stab the throttle, the car LAUNCHES & the tires are history.
So I feel like everything is good, strong, no worn clutch discs....But there is still that super delayed upshift problem.
This started last Sat. & I changed the fluid out Tuesday. Not a full flush, just a filter & fluid change.
Is there anything that could cause the delayed upshifts? TV cable? Dunno how it could suddenly change though.
HELP?
HELP?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: SUPER delayed upshift cause?
Broken TV cable or stuck TV if you've got the TV checkball installed, or a stuck governor.
Car: 87 GTA
But....Isn't the TV in control of downshifts? Not upshifts? If not.....Could it have broken? Why the sudden change?
One minute its fine, next it isn't. Change the fluid, its good. Test drive again a few days later....Bad again.
Doesn't seem to be a pattern.
Engine: 383 Carb
Transmission: 4L60
The TV gets stuck in its bore in the valvebody. A TransGo shift kit will fix it, either the SK 700 or the SK 700 Jr.
Car: 87 GTA
The tranny got a full rebuild 20,000 miles ago & a shift kit put in at that time by the previous owner.....WHAT shift kit & stock or not stall, I dunno.
Engine: 383 Carb
Transmission: 4L60
That's the big difference between the TransGo kits and others. TransGo fixes flaws in the transmission, most of the others just make it shift hard. The term "Shift Kit" itself is actually a trademark of TransGo.
Car: 87 GTA
I adjusted the TV cable, per the FSM...No change.
So I unclipped the TV cable from the TB & it still feels fully connected & retracts, spring loaded, like it should.
The tranny merely feels like line pressure for shifting, is not building. It downshifts after slower down, no problem. Just doesn't like upshifts.
And when in gear, it HOLDS good. A stab of the throttle and the cars GOES, not like the discs are glazed or slipping.
Engine: 383 Carb
Transmission: 4L60
The cable will still retract properly if the TV itself is stuck in its bore.
Car: 87 GTA
What would be the cause & cure? How can it be determined if it is stuck, or what?
This is my first auto, other than the new truck that was under warranty & a 4L60E.
Car: 87 GTA
Is this possibly the problem? It came loose? And the reason it seems to work off & on, is that it "catches" occasionally?
Engine: 383 Carb
Transmission: 4L60
The hooked link attaches to a lever inside the pan that actuates the actual throttle valve in the valvebody. The lever is spring-loaded to always return the cable to the rest position, but this doesn't pull the throttle valve back into its rest position, it has its own return spring in the valvebody. Sometimes the throttle valve and sleeve wear so that they hang up and need to be replaced.
Car: 87 GTA
OK..This is getting frustrating.
HOW CAN I FIX THIS? You seem to have the answers, but won't supply any.
Can this be accessed from above the case? Does the pane and valve body have to come off/out to fix that?
HELP PLEASE!
HELP PLEASE!
Engine: 383 Carb
Transmission: 4L60
Car: 87 GTA
If the TV cable came loose, I'm not swapping out a 3 yr valve body....For a bad cable connection. Again...For all we know, it has a TransGo in it already.
no green
01-09-2016 09:22 PM
Dragonsys
09-25-2015 03:51 PM
