How many bolts in bellhousing?
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Today, to my dismay, my Firebird wouldn't start. The Starter would not engage the flywheel. I took the starter off and found that the starter had been shimmed wrong (darn garages) and took all the teeth off the flywheel! So, now I am to the point where I must remove the transmition. How many bolts hold on the bellhousing? Any other tips for this situation?
Ty
Ty
1 Post
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
There are 5. Two one each side, and one on top. A little tip, remove the distributer cap.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Car: 4
Engine: 6
Transmission: 5
There are 6 on a V8, 3 on each side; don't know about the 6, the other post may have been talking about those.
ICON Motorsports
ICON Motorsports
Engine: 327
Thanks. I will try to find the 5 or 6 you are talking about. I wasnt sure exactly how many there were, or where they were. Thanks for the info anyway.
Ty
Ty
on a SBC there are 2 bolts aranged vertically on the right and left sides of the block. there is another bolt up and inboard from each of the 2 vertical bolts. if you have the bolts out and it's still stuck it maybe stuck on the dowel pins. hope that helps.
ICON Motorsports
1st & 3rd
[This message has been edited by ede (edited January 28, 2001).]
ICON Motorsports
1st & 3rd
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
THere should be 6 bolts, no matter what engine! I've had several of each enigine out, and have always had to remove 6 bolts!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is STILL in shop! (Waiting for my to buy the rods!)
ASE Certified Master Tech
Starting to look like the Kicker poster child!
Working on:
145 MPH IROC Speedo
Building 430 HP 350
1 Post
I must have been wrong. I couldn't remember. All I could think of is the point on the top. On my 231 buick V6, it didn't have that peak, so I just got a little confused.
