TALLER GEARS FOR A BORG WARNER 9 BOLT?
I have an '89 IROC-Z with the 350 tuned port in it, mostly stock. It has the standard Borg Warner 9 bolt rear end with 2.77 gears. I was wondering if there was any taller gear sets out there for that rear end? So far I haven't been able to find any. Please let me know.
Car: 89 Formula
Engine: 383 SBC/HSR
Re: TALLER GEARS FOR A BORG WARNER 9 BOLT?
The carrier would need to be changed to be able to lower your gears, I just noticed that. I believe you have a 2-series carrier.
www.9bolt.com
http://ratech.stores.yahoo.net/79bogmax.html
Between these two you should be fine!
Do a quick search for 9 bolt on here. There was a thread not too long ago that listed a few more sites to get parts.
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
The 3.27 would be a series-3 carrier. You can also find ring and pinion sets at Randys Ring & Pinion: http://www.ringpinion.com/PartsList....b-Differential
MotiveGear.com has BRAND NEW ring and pinion sets for the Borg-Warner 9 bolt. I just bought a 3.7 set.
1 Post
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
They carry 3.89's also...Which I may try to get and pull these 4.10's back out to sell...I'm going through the traps @ 122mph @ 6600 and I still want to spray a ton more.
1 Post
Car: 89 Formula
Transmission: TH 700R4
just an FYI---taller means lower numerically. (ie 2.56 are taller then your 2.77)
Shorter mean higher numerically which is what you want.
Check these guys out...
JT Differentials
I got my rebuild kit along with my 3.70 Motive/Yukon gears from these guys, ask for Jeremy. Great to deal with and fast shipping.
JT Differentials
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Wow 9bolt.com is back up! Posi cones! Excellent!
Car: 87 GTA
Maybe he wants top end speed? With a 6-speed, tall gears still feel good around town.
hectre13
12-11-2023 08:14 AM
theshackle
09-17-2020 08:26 AM
ambainb
04-25-2016 09:21 PM
