t-5 to a tremec tko600
Old 09-07-2008 | 12:54 PM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
Hi all! Long time reader not very many posts though. Any ways I have a t-5 right now that on the outs. Its lasted through lots of abuse and I have decided to go with a tremec TKO600. This is probably a typical question but I have done some searches and still not quite clear on what I can use of my t-5 set up. My questions are can i use my old bell housing, speedo, and cross member? Will my drive shaft length be OK? Do I need a different yoke?
Old 09-07-2008 | 10:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: t-5 to a tremec tko600
you need a yoke, the driveshaft is fine. You need to mod your crossmember or go aftermarket. You need an adapter to go between the trans ans the bellhousing.
I would HIGHLY recommend Fortes Parts Connection for the tko setup. He has everything, except an after market crossmember. He does sell, i believe, parts to adapt your stock crossmember. Other than that if you give them a call and ask questions he will get you everything you need.
Old 09-12-2008 | 06:02 AM
huffediroc's Avatar
Car: 87 iroc
Thanx for the reply, I'll give him a shout.
PurelyPMD
05-05-2016 05:57 PM
Zane Story
10-08-2015 01:40 PM
topteam54
10-06-2015 01:21 AM
luvofjah
09-26-2015 09:28 PM
DARKmj16
09-09-2015 05:07 PM
