th350 to 700r4 swap
th350 to 700r4 swap
I have been doing some research but still can't find exactly what I'm looking for.
I'm swapping because I need the overdrive as this is my daily driver.
I need to know everything that I will have to do in order to swap from a TH350 to the 700r4.
driveshaft?
converter?
lockup?
crossmember?
vacuum?
wiring?
thanks!
driveshaft?
converter?
lockup?
crossmember?
vacuum?
wiring?
thanks!
Car: 87 Z28
Engine: 406 SBC
Axle/Gears: 4:10's,Eaton Posi
Re: th350 to 700r4 swap
Some general info can be found here;
http://transmissioncenter.net/700R4_Swap_Info.htm
Car: 87 Z28
Engine: 406 SBC
C409
09-01-2015 03:42 PM
