Stronger rebuild possible on T5?
How strong can I make my T5 in a rebuild? are far better than stock parts available? from where?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
ICON Motorsports
Jester there are no real upgrades, sorry to say. There's racing grears for it, however their just as stong as stock and cost 2 grand.
Then there is the counter gear sync upgrade, which contrary to popular belief is for the WC model too.
You can try to upgrade the input shaft bearing to T5Z spec, however I do not know if Ford spec T5 parts will work on the GM spec T5.
Other then that your best bet is to get an aftermarket shifter with adjustable stops and run either synthetic 5-30 motor oil or synthetic ATF.
Checkout these pages.
http://www.fordmuscle.com/archives/2...t5/index.shtml
http://www.5speeds.com/t5.htm
http://www.geocities.com/oldwestraci...5TSB/T5TSB.htm
http://home.att.net/~david.d.gray/t5rebuild.htm
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
www.gearzone.net for the 5th gear stabilizer.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Jester, no problem. If you take on the task of upgrading to T5Z input shaft bearing, I'd be very interested in the out come. If the GM v8 and Ford v8 input shafts are the same diameter I see no reason why you couldn't upgrade to it. However I do not know if this is the case. In either case good luck.
3.8TransAM
09-27-2015 08:37 PM
